1 - 4 of 4 Posts
I moved the axle forward without moving the upper spring tower forward to match?
If It's forward with the radius arm flat at ride height, then it would move back with up or down travel, right?
I can see the bennefit of having the coil spring perfectly straight on a 4-link setup. But radius arms, why not mount the brackets a little forward to fit an even bigger tire? The spring would bow a little to the front?????? Would it straighten out with compression? or would the bow get worse?
Basically what I want to know is:
why do I need to have the coil spring straight at ride height? Is it gonna bow enough to spit it out?
This is just a thought in process... I havent drilled any holes yet :shocked
Probably should have posted this in the newbie questions thread. These are some stupid questions.
1 - 4 of 4 Posts
