1 - 20 of 22 Posts
initial start up? Hope you broke the cam in correctly unless it is a full roller.
Urban Assault Bronco
no cam break in yet... was just trying to keep it running
you should not let it idle any, once started you need to crank the engine rpms up to supply enough lube for the cam lobes
for how long?
who ever did the grind on the cam should have given you instructions on how to do so
its an edelbrock performer plus camshaft. i dont see it anywhere on the paper they included with the cam and lifters
model number? or part number
Discussion Starter #9 (Edited)
ugggh nevermind i missed this somehow. edelbrock 2167
CAUTION: Change the engine oil and filter before start-up. Do not
allow the engine to run under 2000 rpm for the first half hour. Slow idle
speeds will result in severe cam and lifter wear. Start the engine
and bring to break-in rpm
Discussion Starter #11
it was running less then a total of 4 minutes
and thanks bud.. just gotta get a few things before i want to do a cam break in. antifreeze (2 brand new gallons totally disappeared from my garage) and i need a longer throttle cable (mine is too short).
worst thing that can happen is you make a lobe go flat. then you just need a new cam and lifters.
press ALT+F4
Actually, you need to run it at 2000+ (Usually for 20 minutes) to keep the lifters spinning in their bores. No lifter spin = wiped cam.
Congrats on getting it fired up. It looks and sounds good.
Edit: Don't freak out... it's usually the high lift cams with heavy valvesprings that wipe a cam quick.
Discussion Starter #14
yeah this cam is actually quite small
Duration Advertised 272° Intake/282° Exhaust
Duration @ .050'' 194° Intake/204° Exhaust
Lift @ Valve .460'' Intake/.480'' Exhaust
Lift @ Cam .265'' Intake/.280'' Exhaust
Lobe Separation Angle 110°
Intake Centerline 105°
Intake Timing @ .050" Open 8° ATDC
Close 22° ABDC
Exhaust Timing @ .050" Open 37° BBDC
Close 13° BTDC
Discussion Starter #16
thanks bud
Discussion Starter #18
thanks bud.. cant wait to do my cam break-in and tuning today so i can take her for a ride
Discussion Starter #20
i think he meant the 1980 and newer bronco's
1 - 20 of 22 Posts
