I call BS, the solenoid is engaged by the starter relay and once the solenoid is engaged it drives the gear into the flywheel via a fork doohicky.The 91- starters do not have a solenoid on the starter,they use an internal winding and a plate to engage the starter drive,the power for engaging the starter comes from the fender mounted RELAY(it is not a solenoid).The 92+ starters have a starter mounted solenoid to engage the starter drive and provide power to the starter from the battery.
If you can I'd love to see a few install pics and hear opinion once you have it installed. Mine is going to be ordered soon.:thumbupI went ahead and ordered a starter from Ryan
Will do!If you can I'd love to see a few install pics and hear opinion once you have it installed. Mine is going to be ordered soon.:thumbup
Well I'll be dipped in dog shit, you're right! I thought I had one of those apart once, but I guess not.Well Waltman.First off,the top starter is a 92+(that is 1992 and newer)and it does have a solenoid like I stated in my post. For the second starter,check out this web page http://en.wikipedia.org/wiki/Automobile_self_starter ,scroll down to the "gear-reduction starters" and read the portion that starts with "Ford also issued".The first portion of the second sentence is as follows:"This type of starter eliminated the solenoid".That having been said,I suppose that the second starter engagment system could be a type of "solenoid system due to the fact that electrical current moves a mechanical device and closes contacts to provide power to the windings".:scratchhe IMHO,It's just easier to think of one system as having a starter mounted solenoid and the other system as not having one.:beer
Anyhow,you can install the newer gear reduced starter in place of the old type by running a jumper wire from the larger battery cable post(with the battery cable) on the solenoid to the smaller "S" terminal-The fender relay will then apply power to both the "BAT" and "S" terminals on the solenoid causing the starter to operate.
but can you use the earlier type on a newer bronco ?The 91- starters do not have a solenoid on the starter,they use an internal winding and a plate to engage the starter drive,the power for engaging the starter comes from the fender mounted RELAY(it is not a solenoid).The 92+ starters have a starter mounted solenoid to engage the starter drive and provide power to the starter from the battery.
