Hi! New to the forum. On my second FSB...had a '87 back in '91, and just bought a 89 this year to pull a boat around. Basically I drive it once in a while to keep it running and pull the boat a couple miles to the ramp and fifty miles to the Keys every so often.
Although it is an "OJ Special", I call it "John Elway" 'cause it is a 'slow white Bronco' :duh
It'll get some attention, but between my Jeep and boat, I have to share the budget when it comes to the toys. Would like to mod it up someday though! For now it;ll be a keep it running and enhance as I replace.
The 351 motor has 180k+ on it and runs pretty good, but wonder if it is a ticking time bomb? I realize it is a subjective question...don't really know the history of it's previous use, but since I am in FL, I think it is a pretty safe bet that those are a lot of highway miles. I do hear a ticking/ratttly sound when it is at higher revs, (but not at idle)....At first thought it was a valve or lifter going, but now think it may be the exhaust header gasket (see next paragraph)
The last owner started to put headers on it, but only did the 'easy' side (drivers side). Is it bad to run around with one header and one stock manifold? It is hard enough to get to the spark plugs on the passenger side, so I am guessing the ex. manifold bolts would be a PITA...? i am half considering cutting out all the wheel well lining to make getting in there easier...is this a good or bad idea?
