Tighten adjusting nut to 50-60 ft. lbs. (68-81 N.M.) while turning wheel back aqnd forth.
Note: Adjusting nut will not tighten past 70 ft. lbs. (95 N.M.).
Threaded portion of nut will ratchet in the assembly.
Apply inward presssure to spanner lock nut wrench to disengage locking splines, back off adjusting nut approximately 1/2 turn (180 degrees). Retighten adjusting nut to 15 ft. lbs.(20N.M.). Final end play of wheel on spindle should be 0-.006.:beer
PS I replaced with the three piece design as mine finally gave up the ghost and broke inte several pieces.It is the Warn automatic hub change over conversion at least for mine it was.
