1 - 12 of 12 Posts
1984 Ford Bronco
So I bought some beautiful rims not knowing bolt patten was a thing and it turns out my bronco is 5x5.5 and the rims I bought are 5x4.5 bolt pattern....
so right I’m trying to decide whether I should buy a set of wheel conversion adapters or should I just buy a new set of rims.
I’m a little effy on wheel conversion adapters because I hear they can be bad/dangerous especially when off roading. But it would save me a lot of money.
thoughts?
what would y’all do?
Your front hubs won’t fit through most sets of 5x4.5 wheels. I’m sure some Jeep guy will buy those 5x4.5 wheels. And adapters will probably be $200 even if your hubs fit through
1993 F150 XLT 302 Auto 4x4 2.5" Lift on 32's
I would try and return them if purchased from a company, if not possible then sell them for somewhat of a loss.
I would do as suggested above. I wouldn't run adaptors.
Reactions: Rodribra001
Addicted to Junk
I run wheel spacers, and still recommend you getting the proper wheels.
Only some F100s had the 5 on 4.5 pattern. Otherwise, half ton fords were 5 on 5.5 from at least 73 until 97.
I’ve seen exactly one of those 5x4.5 bolt pattern f100’s in my life.... pretty rare I think
Reactions: BigBlue 94
Cut your losses and try to resell. It happens to the best of us.
Addicted to Junk
Same here, an early 80s model I considered buying. But didnt
5x4.5=ewww jeep lug pattern. Get the proper 5x5.5 bolt pattern. What do you plan on doing with the truck, if you aspire to swap in 1 tons or 3/4 tons save on the cost of wheels because you'll need an 8x6.5 or 8x170mm wheel for those.
1984 Ford Bronco
Discussion Starter · #10 ·
Are you talking about changing the chassis/frame of the truck ?
1989 Bronco XLT 351W with C6, manual locking hubs. 6” suspension lift with 35” Cooper tires
Sell and buy correct. In today’s market, you should be able to sell no problem!
If you plan on swaping 3/4 ton or 1 ton axles, hold off on the wheels because the former have different lug patterns than the stock 5x5.5 axles on your BKO.
1 - 12 of 12 Posts
