I'm planning on going to 1 tons and was wondering what size wheels I would need. Can I run 15's or do I need to go to at least a 16" wheel?
Engineer
16's fit without any issue. With 17" and up tire prices dropping and the selection increasing I can't see ever wanting 15" wheels again.
You can run 15s if you get them with 3.5" or less back spacing, and do some grinding on the caliper brackets. I kept the big twin-piston Ford brakes, with 3.5" back spacing and had to grind about an hour's worth from each side, and on the 60 rear(not 10.25) did a chevy-disc swap and had to grind just a pinch on those.
So, without grinding, you're gonna want atleast a 16, if not 16.5 to 17.
The above is a typo, it's 2.5" or less backspacing to make 15s clear.
Just get 17s. 16s will clear, but 17" is fast becoming the industry standard.
Is that without grinding? It's been 4+ years since I got my beadlocks and measured them, so I could be wrong, but I thought mine were 3.5".
And if I had it to do over with, or just had the funds now, I'd just go 17s and screw all the grinding
B350 built at THE SHOP
I'M RUNNING 16 INCH WHEELS, DANA 60 FR0NT AND 10.25 REAR, N0 GRINDING WITH DISC BRAKES IN ALL 4 C0RNERS
