1 - 2 of 2 Posts
Does anyone know if 02 dodge and 03 chev 3/4 ton have the same bolt pattern as a 90 f-350? I'm looking at some wheels but the guy doesn't know if they are the 8 x 6.5. He just knows they fit chev and dodge.
The bolt pattern should be 8 on 6.5. The Ford Stupid Duty is the only one that uses 8 on 170mm.
*side note
Most stock Chevy and Dodge wheels won't fit over the hub of a Sterling 10.25 and some Chevy 3/4 ton stock wheels won't fit over the hub of a Dana 60.
Also avoid concentric wheels. Use ones that center on the lugs instead.
Another thought...IIRC-Late model IFS chevy wheels have deep back spacing...just something to think about.
I'd put a tape measure on things and try a test fitment before you got your hopes up.
1 - 2 of 2 Posts
