1 - 19 of 19 Posts
89 bronco. Dana 60 SAS
i have a set of 38.5 x 15 mud tires on my truck
i have them mounted on my factory rims i think they are 7 or 8 inches wide. it looks good from the side, but when you stand in front of it ot in back of it . it looks like the wheels dont stick out far enough. if i get a wider rim would it help me out with getting them to stick out father.
i dont know too much about back spacing and stuff like that so any comments or suggestions would help me out a lot.
a rim thats wider with the same backspacing will stick them out more. Stock wheels I believe have a 3.5" backspace, so a 10" wide wheel with a 4" backspace will move the tire out an inch or two.
just a question. what about those trucks i see that the wheels stick out like half a tire. i just wanted to make them stick out more because i have bush wacker cut out fender flares and it just looks goofy to me i wanted to get the tires to look wider basically (stick out more) to make the truck more proportion.
Engineer
A 15x12 with 4.5 inches of backspacing would kick them out a lot
Former owner of Shadofax
Are you equally concerned with breaking axles?:popc1:
ive never broken any axles. i drive my truck to work and backl every day. on the weekends i beat the crap out of the truck offroad. i thought when you do higher(lift) you go wider.
i just got done a 6 in lift and 3 in body. just want it to look a certain way
does anyone know where i can get a set of rims with that kind on back spacing and that wide. any info would help. ive tried ebay.no luck
thanks a lot
38.5 gumbo mudders, a TTB front and 8.8? and you beat the crap out of it, and have broke nothing?
Discussion Starter · #11 ·
i dont go climbing mountains or huge rocks and stuff. i have trails near my house. mostly lots of mud i play around in. driving near Rail Road tracks they got lots of trails to drive in, its fun cause its the only thing around me.
Discussion Starter · #12 ·
The transmission is the only thing that has gone major wrong. it was replaced with a junkyard one.
What wheels did you find with the 4 ish back spacing? I am thinking of a similar thing, with the cutout flares and all and would like that similar look... although I will have a 60 front and 10.25 rear, just to be on the tougher side for the 44's I want (as I am sure Shadowfax can attest to after brow beating me in previous threads) =]
10X15's with 3 3/4 backspace would do nicely. Inexpensive from US Wheel.
Discussion Starter · #15 ·
i found some i liek on this site
http://www.petepaulsen.com/Catalogofwheels/Truck Mod.htm
check it out.
there the cheapest i found.im not a big fan of chrome so im gonna go for the white ones.
I thought the less backspacing - the more they stick out, while the more backspacing - the less they stick out. For instance, a wheel of the same size and diameter with same tires on it with 3.5" backspacing should stick out more than the same wheel/tire combo with 4" backspacing.
Discussion Starter · #17 ·
i dont know how any of the back spacing stuff works. If someone could explain it. It would be helpful before i order rims.
thanks
thanks
It's simlply the measurement from the BACK of the wheel where the lugs bolt to the axle INWARD to the wheel lip.
Example: an 8" wheel with 3.75" of BS means that you can measure apx. 3.75" from where the wheels lugs are bolted to the axle to the wheels inner lip. Obviously this means you have roughly 4.25" of distance out to the outer wheel lip (which is the one you can see). so backspacing refers to that inner wheel measurement. Offset should not be confused with it.
So little backspacing means you see a lot of rim on the outside (side that is viewed), and tends to offset the whole wheel/tire combo outward. Offset is how much you are deviating from the wheel centerline IIRC (+ or -)
Discussion Starter · #19 ·
thanks helped a lot. plus i looked up some diagrams online with pics.
1 - 19 of 19 Posts
