1 - 20 of 30 Posts
Charlie don't surf..
'92 Ford Bronco XLT
Found this plug hanging out all by itself under my hood when John and I were working on the powersteering box..Not sure what it goes to as there were no vancant spots for it to plug in to. It's on the drivers side and ties into the main harness over there. Any ideas??
'92 Ford Bronco XLT
Ignition reset?? What does that do?:shrug
'92 Ford Bronco XLT
We thought it was the spout connector plug at first but iI found that plug over by the fire wall, and this one is way bigger than the spout connector.
'92 Ford Bronco XLT
ummmm that would truly suck if it was an FI plug...I'm going to check that as soon as I get home..Wouldn't I have noticed a problem with an injector not plugged in, like my rig running like shiz??
The Anti Yam!
It does kinda look like an injectore plug. It just looks like it's an awfull long way away from the rest of the injector plugs, and it shouldnt come of the main harness by itself on the drivers side. If it is an injector plug, it should have the others with it.
'92 Ford Bronco XLT
If not an injector plug or ignition reset plug, any other suggestions?
do you have ac. if there isnt a compressor or yours is not hooked up, that is probably it. mine is not connected and it looks just like that. who knows...
'92 Ford Bronco XLT
Discussion Starter #12
Octane switch?? what's that?
The Anti Yam!
Yup it looks like that to.
The Anti Yam!
Its somthing on EEC-V vehicles so I dont think you have one
look here for an explanation
http://www.gagfish.com/howto/octane/
ther is a picture on that page of it
But like I said, thats not what it is. It just kinda looks like one.
'92 Ford Bronco XLT
Discussion Starter #16
No, its not the A/C, that's connected..
College User
It is nothing, on the f-series trucks it would have connected into the power steering sensor. If you look on a f150 it will be connected, and if to want to test it should be able to reach the power steering assembly. Don't worry about it.
'92 Ford Bronco XLT
Discussion Starter #19
Cool, thanks Steve.
1 - 20 of 30 Posts
