jam0o0 said:
would it be too hard to drill the rad tank on the top neer the upper intake hose? and tap the hole for a temp sensor? hey six what is that first pic showing? ::edit:: ok i see it's the engine side of the upper hose. is that plug you took out in there stock? and is it on my 95 351w? sorry for all the questions i'm just thinking about getting a good temp gauge and wondering where to put the sensor.
::edit:: i got an idea. cut the upper hose, make a pipe withe a thredded bung welded on the side. two hose clamps and slide it into the hose. any thoughts?
Jam0o0
No that T-stat housing is not stock
My stock aluminum one was so pitted it was starting to leak. Went to Ford and the counterman and I were laughing histerically at what Ford wanted for a new stocker.
Luckily both he and I were too stupid to check the affordable, chrome ones in the Racing catalog because they're 90 degree units for Mustangs only (no trucks, no bigger cars).
No sir, that there is the finest cast iron
histerica ) unit that can be manufactured using good old fashioned Chinese prison labour. It was so bad I had to spend 15 minutes with the die grinder removing casting flash to get the hose to fit on it properly.
The good news is it was the correct 45 degree angle for our trucks and it had that threaded hole that fit the temp sensor perfectly (and it was dirt cheap).
NO you cannot drill into the header tank (you risk taker you). Yes you could do the hose interupting idea no trouble.
Choice is yours
Sixlitre
