I have to replace mine. Unfortunately I have not been able to find it at autozone or advanced auto parts. Ford wants $52 :shocked . Napa has 3 (around $25) listed for a '95 351 but none in stock. Any suggestions?
Thanks.
Thanks for the fast response. It was broken while pulling the throttle body, the plastic inlet was old and snapped. So just to make sure, plug the fitting on the throttle body for now and deal with it later. It won't effect EGR or anything? It might be a dumb question but never had to mess with it before. Thanks.
OUT OF BUSINESS / M.I.A.
no it effects absolutly nothing else. If you leave it pluged in and just remove the vacuum hoses you won't even get a trouble code.
As with everything make sure the vacuum ports are pluged at the throttle / intake
vacuum leaks are bad :(
69 Bronco crawler, 93 EB cruiser
damn near every ford vehicle has this valve with the same part #, and they are pocket size, so hit up your local junkyard and grab a few. I got several freebies last time I was at the upullit, and they came off lincolns and ltd's. :hump
