1 - 20 of 44 Posts
Welcome to the jungle
Okay, I searched, but couldn't find anything helpful.
What size winch are you running? are you happy with it? Does it seem to have enough power? Do you wish you had purchased a bigger one? I'm looking into outfitting my Bronco with one, I just don't have money to buy more than I need. Would a 8,000 pounder do it? I'd sure buy a snatch block with it. Thanks
scrounger extrordinaire
whats the most you could afford? the MM12K was $599 last year. more pulling power than anything in that price range no matter the debate on how good it is or what features it has or hasnt got. i would say thats the deal for raw pulling power, but if you want other features & less power you will be paying more. i think warns 8K is more than $599. you could save a little longer maybe?
I just ordered my milemarker 12K.It comes in tomorrow.As for the harbor freight winch,you get what you pay for.If i was in your position,i would buy a MM winch.There is a MM 12k on ebay right now for 599 shipped and out the door
CheeseBurger Milkshake!!
I've got a MileMarker 9k hydraulic, overall I'm very pleased with it performance, strength and reliability. Four years of heavy use without any hint of problems or failure. It does everything I want it to and more...........money well spent.
No avatar required
Lonestar_Bronco said:
Actually (don't shoot me for saying this) I was thinking about this
8,000 pound winch
I've seen a few pics of your rig wheeling. Do yourself a favor and don't buy that winch. You will be happy you didn't. Don't be afraid of buying a used winch. Especially if you get it for the right price. If you have the $$ right now go with a MM. But if you have to have a winch right now,and the harbor Freight is all the budget will allow,than any winch is better than no winch..at least until it breaks.
Steve
Screw the Jeep Thing
I have a warn 12K and love it other then I killed my batteries and the think pulls like 900 amps under full load.,
www.easttn4x4.com
I've looked at that winch also. If you have a mostly stock truck it may do as long as you don't do any long pulls. I have a smaller winch and hate it. It never seems to work for me. When I get stuck I'm really stuck and need real power. I'm going with the milemarker hydraulic. It can run as long as you want with no load on the battery as long as the engine is running. The main problem with cheaper electrics is heat. Watch the heat build up and you might be ok.
I am running the Warn HS9500 winch not any problems and it is the fastest winch you can get other than the Warn 8274
College User
I got the MM E12K is good but if the angle is wrong I have stalled it a bunch andBith times I had to use it for myself it did NOT get me out. But then again when got stuck it was bad. This was in my 91 approx 7000lbs...
wow. i wonder what the best way to feed an electric winch? dual batteries? triple batteries? convert it to 24v? i wonder what i would have to get for a p/s pump to run hydro assist and a hydraulic winch? will a beefed up saginaw work? i bet i would need a reservoir for extra fluid capacity.
www.easttn4x4.com
The milemarker hydraulic doesn't need anything special. Just put it on your existing pump and go. It comes with everything you need. As for electric, 24v is the best.
College User
You can run an electric fine with the truck off and still start up. I dont have a red top or anything special either. And the winch is not going to be used a ton, and if you have an electric keep the engine running if possibe.
Discussion Starter · #18 ·
axaviere said:
I wonder what I would have to get for a p/s pump to run hydro assist and a hydraulic winch? will a beefed up saginaw work? i bet i would need a reservoir for extra fluid capacity.
That probably wouldn't be a half bad idea. A filter and cooler would probably be good ideas as well.
1 - 20 of 44 Posts
