781 - 800 of 849 Posts
Discussion Starter #785
Those aren't fragile...
That was my thought when I saw the box. I read it out "A Christmas Story" style when I saw it.
1979 Bronco Ranger XLT, 400m engine, C6 trans, D44 front with Dick Cepek manual locking hubs
nice, springs made from glass or what? not to bad!
How much "lift" will these add to the front? What is your plan for the rear? Patiently awaiting your install, hah!
Discussion Starter #789
Which ones did you end up getting?
According to Broncograveyard's listing these are 5" lift coils. I've read reviews that specified they give more lift than that, so we'll see once I get them on. I'm not in a big hurry, so it may be a bit before they go on.
I'm going with the Deaver 4" leaf springs in the rear. Also considering extended radius arms.
Do you need to upgrade the shocks to make up for that extra lift?
Discussion Starter #791
Yes. These shocks are pretty shot to begin with. I was waiting to flex out my factory suspension with the shocks and swaybars removed to see what I could get out of it before ordering new shocks, but I'll do that after I get the lift sorted out.
Dope dope, I'll probably end up mimicking your setup for lift because I dont know jack about it all lol
Discussion Starter #793
I don't know jack either, but I spend a lot of time reading. There's a gazillion threads with lifts on this site. Some are good, some are bad, but it gives you an idea. Pretty much goes for everything, lifts, exhaust, engines, etc etc.
Discussion Starter #794
I also finally got confirmation on my hydroboost order the other day. Remember that thing I was excited about getting? lol. I nearly forgot I had ever ordered it.
I called them right after every date they gave me for when they were expecting it to be in stock, which was about once a month. I even kept the original voicemail I got telling me when to expect it, because I didn't want to feel like an asshole about expecting the timeline they gave me. Either way, it's supposed to arrive tomorrow according the to tracking in an email I got this morning.
I've got some other stuff coming as well. I'm just doing the "usual" upgrades guys do to the 78/79's.
True but it seems like you're doing every fix/upgrade that I want to end up doing regardless so I'll take your word for it lol
Discussion Starter #798
GM style cast iron master cylinder along with a couple of hoses.
There used to be a label on this box within a box, but they cut it out. I'm assuming it was a label from the manufacturer sending it to Wildhorses as Wildhorses doesn't sell this stuff separately, just in a kit, while the manufacturer (hydratech) does sell things individually.
Manila folder with instructions and a sheet of paper telling you that things may be messy once you get to the bottom of the box.
More hoses sealed in a plastic bag and wrapped up in some paper.
And I didn't bother to pull out the actual hydroboost unit as I could see it had indeed leaked fluid out and I wasn't prepared for that mess in my kitchen while I was lounging in my PJ's, so I'll inspect that later on when I'm good and ready... and most likely outdoors.
ngl I'm pretty darn jealous, did you get that steering box ported so that it would work with the hydroboost/saginaw pump?
Discussion Starter #800
You mean for hydraulic ram assisted steering? No. I didn't think I'd ever put on tires big enough to need that. I mean, it can be done after the fact I suppose, but it was an extra $110 for something I didn't/don't think I'll use.
Otherwise, I don't need to change anything else. I have a Saginaw pump with dual returns on it, so two lines will return to the pump, one from the hydroboost and another from the steering gear. Something like this.
