1 - 20 of 52 Posts
Possibly one from a 1999+ superduty.I know the bolt circle is slightly different,but that could be altered or redrilled to the correct pattern.To try, you could remove the wheel studs so that you could see if the rotor would fit over the hub and have an offset that would work.
Master Bater
Discussion Starter · #9 ·
IM using shawns kit. he responded with a link to a guy that R and D'd it I guess. I did find one guy on PBB that has done this by turning the back of the hub so the chevy stuff slides on. Im going tomorrow to see if I can get that done, otherwsie I will pull the grinder out, but would prefer a more accurate way of doing this.
I emailed Shawn awhile back and I believe his response was..... some modification is required.... meaning grinder' down
Here is a picture of the trouble hes having with the calipers as you can see it won't seat w/o turning or grinding......
PLug... I haven't bought a great lakes bracket yet, just did some of the researching on it, im starting to second guess buying his.... sorry if I mislead you in anyway about his product I just knew he made a bracket
my axle is still sitting in my garage, it might get my attention now that my engine is done, but doing the swap means I need to swap wheels and tires to 16" or grind for 15" clearence, either way I need 8 luggers, and I need money for a locker and gear install, so yea its going to be put off for awhile.
I gave all of my disc parts to Will because his rear tanked so he threw my rotors and calipers on his 14 bolt.
so im not obligated to go chevy 3/4 ton rotors as before, what rotor is semi-fitting, Front Ford Van 3/4, 1 ton?
I think there are a few of those at the yard I might have to go score one and see how it fits.
Will fabbed up his own bracket template and got a shop to cut it out, Im thinking i might be doing the same.
In fact I think ill go to the junkyard today.... I'll let you know what I find if I go
1 - 20 of 52 Posts
