I recently bought my Bronco and was tring to install a c.c. player,
the wiring harnesses were gone when i bought it so I found some wiring diagrams on the internet.
:shocked But when I hooked everything up (what I thought was correct) My trans wouldnt change gears and the odometer wouldnt work.:shocked
I have to hook a ground wire from the truck to a speaker wire from the radio for the trans to work properly. but my radio still doesnt work!!!!!!!!!!!!
It doesnt make sense to me!
:shocked
Sounds like you stole a ground that the transmission was using, and now it's trying to ground through your radio.
hey, welcome to FSB. I agree that it sounds like the trans is trying to ground to to speaker. Try by passing the ground on the wiring harness. Just go from the head unit to a new ground. See if you speaker wires are ok, unless you've replaced them already.....
