1 - 2 of 2 Posts
95 bronco sounds like its trying to go into 4 wheel drive at 15 mph grinding noise and when I stop slamming noise front and rear
Yo Steve,
Welcome!
For now, because I'm about to visit my much better-half in H, let's eliminate the 4 wheel drive first.
1356 Electric Shift Operational Test; Remember to block the wheels. This would work for testing manual hubs too, just lock them 1st; "...Place transfercase in 2HI or Neutrall. 2. Lying under vehicle, turn front drive shaft (one direction only). 3. Automatic hubs should lock after 1 to 5 turns of driveshaft (one direction only). After step 3 the hubs should lock, youll know they are locked becouse you will hear a click from both hubs and you will no longer be able to turn the front drive shaft (in the same direction). If this is not the case then continue to step 4. If you can no longer turn the drive shaft (in the same direction) then skip to step 7. 4. If you can still turn the drive shaft (one direction only) then one or more of your Auto hubs is not working. 5. Continuing to turn the Drive shaft (one direction only). 6. Look at the u-joints for the front stub axles, if both are turning then both front hubs are malfunctioning, if only one is turning then the one that is not turning is locked and the one turning is malfuctioning. Replace as necosary (preferably with manual hubs, Auto hubs have Yams in them) 7. To unlock the hubs, turn drive shaft in opisat direction untill you hear a click from the hubs. To check for transfercase engagement. 1. Place pushbutton transfercase in either 4 HI or 4LO. 2. lie under vehicle. 3. You should not be able to turn front drive-shaft in either direction. 4. If you can turn the front drive shaft then your transfer case is not shifting properly..."
Source: by Gacknar (The Mall-Crawler, Jeremy, "Big grey megga beast") at FSB
Tire Diameter/Circumference & Air Pressure Differences; "...You will recall that at the beginning of this section, we mentioned that we had made sure that all four tires on our truck were the same size, were worn the same amount, were inflated to the specified pressure and were subjected to reasonable loading. Avoiding driveline windup was the reason for this. Figure 18A shows that tires of even slightly different size roll different distances every revolution. Figure 18B shows that the same effect is true for tires that are the same size but inflated or loaded differently. Operating a 4 x 4 in 4WD with tires of different size or inflation will produce driveline windup, even when driving straight ahead! If the vehicle is being driven in 4WD on dry, hard pavement, the driver will notice drag and may experience the hop, skip, bounce effect as the front or rear wheels release the windup..."
1356 Electric Shift Troubleshooting & Repair - BEST PROCESS!
Source: by Dustin S (Dustball, Mellow Yellow, Mr. Laser Boy) at 1989 Ford Truck F 250 4WD Pickup V8-460 7.5L - Diagnosis of the Electric Shift 4 X 4
LOCKING HUBS, Manual Operational Test; "...To CHECK FOR PROPER ENGAGEMENT, dial both hubs to LOCK and raise the front left corner of the vehicle off the ground. Spin the lifted tire. The drive line will turn if the Hub is engaging properly. TO CHECK FOR PROPER DISENGAGEMENT, dial the lifted wheel hub into FREE and spin the lifted wheel. If the drive line does not turn AND you hear NO ratcheting sounds, the hub is disengaging properly. Repeat step 5- 6 with the right wheel & hub. NOTE: The hubs are not required to seat against the wheel housing when installed, they may move in and out quite easily. This float is normal and will not affect performance..."
Source: by Warn®
Ratcheting Noise - Self-Engagement of Automatic Hub Lock TSB 97-6-28 for 95-96
TSB 97-06-28 Ratcheting Noise from the Front Axle and/or a Self-Engagement of the Automatic Hub Locks, Motoring Torque
ISSUE: A noise from the front axle and/or a self-engagement of the automatic hub locks may occur on some vehicles. This may be caused by a combination of high axle motoring torque and hub locks which require little torque input to engage.
ACTION: Reduce the axle motoring torque by replacing the differential side gear thrust washers and adjusting the pinion preload. This procedure will reduce the axle motoring torque to a level below the required hub lock torque to engage. Refer to the following Service Procedure for details.
NOTE: THE FRONT AXLE SHOULD Be BROKEN-IN FOR 402 km (250 MILES) PRIOR TO PROCEEDING WITH ADDITIONAL DIAGNOSIS OR REPAIRS. TO BREAK-IN THE FRONT AXLE, ENGAGE FOUR-WHEEL-DRIVE, DRIVE FORWARD AND THEN SHIFT OUT OF FOUR-WHEEL-DRIVE WITHOUT DISENGAGING THE HUB LOCKS. DRIVING WITH THE HUBS ENGAGED WILL BREAK-IN THE AXLE. IF THE VEHICLE IS BACKED UP DURING THIS TIME PERIOD, THE HUB LOCKS WILL DISENGAGE AND WILL HAVE TO BE ENGAGED AGAIN BY REPEATING THIS PROCEDURE.
SERVICE PROCEDURE
Remove the front driveshaft and tie a 12-pound test monofilament fish line between the front output yoke of the transfer case and the round locator hole on the side of the transfer case (Figure 1). Drive the vehicle in two-wheel-drive with the hubs unlocked for a minimum of 3 km (2 miles), including some lock-to-lock figure eight turns. Refer to the following two conditions. If the fish line breaks, the concern is being generated by the transfer case. It will require further diagnosis and possible repair. Refer to Section C - Transfer Case Diagnosis And Repair of this article. If the fish line did not break, proceed to Section A - Measure The Motoring Torque Of The Front Drive Axle of this article and follow through all of the service procedure until the concern is resolved.
A - MEASURE THE MOTORING TORQUE OF THE FRONT DRIVE AXLE
1. With the vehicle on a lift, remove both hub locks.
2. With the left axle shaft free to rotate:
a. Slowly rotate the right axle shaft in a clockwise direction using the Axle Torque Metering Socket (T96T-3219-A for F-150/Bronco and T96T-3219-B for F-250, found in the 1996 Essential Service Tool Kit), and a dial or beam-type inch-pound torque wrench. Stop at the highest reading, then restart and record the breakaway torque reading. Repeat this procedure in a counterclockwise direction, stopping at the highest reading, then restart and record the breakaway torque reading.
b. Repeat the procedure in Section A, 2a, for the left axle shaft.
3. With the left axle shaft held from rotating (place a screwdriver in the U-joint to prevent the axle shaft from rotating):
a. Repeat the procedure in Section A, 2a.
b. Repeat the procedure in Section A, 2b.
4. If all of the torque readings through the differential obtained in Section A, 2a and 2b, are 2.8 N-m (25 lb-in) or less AND if all of the torque readings through the pinion (opposite axle held) obtained in Section A, 3a and 3b are 6.8 N-m (60 lb-in) or less, return the vehicle to the customer and ask that an additional 240 km (150 miles), with the hubs engaged, be put on the vehicle and note any additional occurrence of hub lock self-engagement.
5. After the 240 km (150 miles) have been driven, repeat Section A, Steps 2 and 3.
a. If the torque measurements have dropped, the self-engagement should be eliminated.
b. If the torque measurements have not dropped, and the concern continues, proceed to Section B.
B - FRONT DRIVE AXLE DIAGNOSIS AND REPAIR
1. If all torque readings obtained in Section A, 2a and 2b, are 2.8 N-m (25 lb-in) or less, the differential side gear thrust washers DO NOT need to be replaced. Proceed to Section B, Step 2. If any of the torque readings through the differential obtained in Section A, 2a and 2b, were over 2.8 N-m (25 lb-in), replace the two (2) flat differential side gear thrust washers (Figure 2) with the 0.635mm thick washers supplied with the Axle Motoring Torque Reduction Kit (F6TZ-4228-BA). Follow the procedure listed in the appropriate year F-Series/Bronco Powertrain/Drivetrain Service Manual, Section 05-03A for differential and carrier removal instructions.
2. If any of the torque readings through the pinion (opposite axle held) obtained in Section A, 3a and 3b, are over 6.8 N-m (60 lb-in), measure the pinion bearing pre-load to determine if the pinion should be re-shimmed using the Axle Motoring Torque Reduction Kit (F6TZ-4228-BA).
a. Follow the procedure listed in the appropriate year F-Series/Bronco Powertrain/Drivetrain Service Manual, Section 05-03A for differential and carrier removal instructions.
b. While the differential assembly is out of the axle housing, check the pinion for smooth, pulse-free rotation.
c. Slowly rotate the pinion in the carrier using a dial or beam-type inch-pound torque wrench. Stop at the highest reading, then restart and record the breakaway torque reading. Measure and record the torque required to rotate the pinion.
d. If the breakaway torque is more than 0.7 N-m (6 lb-in) greater than the torque to rotate and/or the pinion rotation is not smooth and pulse-free, inspect the pinion bearings for cage deformation and/or irregular roller or cup wear patterns. Replace the bearing (4621-outer, 4630-inner) if either condition is found.
NOTE: USE OLD PINION NUT AND WASHER TO ESTABLISH THE SHIM PACK REQUIRED FOR REDUCED PINION TORQUE TO ROTATE. ONLY USE NEW PINION NUT AND WASHER AFTER REQUIRED SHIM PACK HAS BEEN ESTABLISHED.
e. If the pinion torque to turn is greater than 2.3 N-m (20 lb-in), adjust the shim pack (using the shims provided in the kit) so that pinion torque to turn is 1.7 N-m (15 lb-in). For each thousandth of an inch added to the shim pack, the torque to rotate the pinion will decrease by approximately 0.9 N-m (8 lb-in).
WARNING: DO NOT ALLOW ANY PINION END PLAY IN THE PINION BEARING ADJUSTMENT.
f. While the axle shafts are out of the axle assembly, inspect the U-joints for freedom of movement and replace if seized.
CAUTION: DO NOT USE 80W90 OR 90W GEAR LUBE.
g. Reassemble the front drive axle following the procedure listed in the appropriate year F-Series/Bronco Powertrain/Drivetrain Service Manual, Section 05-03A for differential and carrier installation instructions. Replace the pinion nut and washer with those supplied in the kit. If the ring gear was removed from the differential, replace the ring gear bolts with those supplied in the kit. Fill the axle assembly with 4X4 Gear Oil (F1TZ-19580-A or equivalent meeting Ford specification WSL-M2C191-A).
h. Recheck torque reading in Section A, Step 2a to verify that axle modifications have been performed properly.
i. Return the vehicle to the customer and ask the customer to drive the vehicle for 80 km (50 miles) with the hubs locked to "break-in" the modified axle. To break-in axle, engage four-wheel-drive, drive forward, and then shift out of four-wheel-drive without disengaging the hub locks. If the vehicle is backed up during this time period, the hub locks will disengage and will have to be engaged again by repeating this procedure.
C - TRANSFER CASE DIAGNOSIS AND REPAIR
1. Check the transfer case for proper amount of Automatic Transmission Fluid (ATF).
2. Measure the end play of the rear output shaft using a dial indicator. If the end play is over 1.27mm (0.05), there is a possibility that one (1) of the two (2) rear output snap rings is missing or out of position. Note end play for reassembly purposes. Regardless of end play, proceed to the following Step 2a.
a. Disassemble the transfer case following the procedure listed in the appropriate year F-Series/Bronco Powertrain/Drivetrain Service Manual, Section 07-07.
b. Inspect for missing or out of place rear output shaft snap rings. Repair or replace as necessary. THIS STEP DOES NOT APPLY TO THE BORG WARNER 4407 TRANSFER CASE.
c. Check for a minimum of 0.25mm clearance between sprocket and lockup hub on the rear output shaft using a shim gauge. If insufficient clearance exists, replace rear output shaft (-7061-), drive sprocket (-7177-), and hub shift collar (-7100- for manual shift and -7G362- for electric shift).
d. Inspect the disassembled transfer case for galling in the following locations:
* Between the drive sprocket bore and the rear output shaft journal. If galling exists, replace both components.
* Between the sprocket thrust faces, the rear output shaft shoulder and hub shift collar. If galling exists, replace the rear output shaft, sprocket and lockup hub.
e. Assemble the replacement sprocket and lockup hub on the rear output shaft with a snap ring.
f. Clean pump screen and magnet.
3. After reassembly, refill the transfer case with Motorcraft MERCON® Multi-Purpose Automatic Transmission Fluid (ATF) (XT-2-QDX), or equivalent meeting the Mercon specification, to just below the fill plug hole.
4. If the transfer case diagnosis and repair has not resolved the concern, proceed to Section A - Measure The Motoring Torque Of The Front Drive Axle.
The Axle Motoring Torque Reduction Kit (F6TZ-4228-BA) contains the following:
* Two (2) 0.025" Differential Side Gear Washers
* Two (2) 0.005" Pinion Shims
* Three (3) 0.003" Pinion Shims
* One (1) Pinion Seal
* One (1) Pinion Washer
* One (1) Pinion Nut
* Ten (10) Ring Gear Bolts
* One (1) Keystone Boot Clamp
* One (1) Instruction Sheet (I.S. 7144)
OTHER APPLICABLE ARTICLES: NONE
SUPERSEDES: 96-26-20
WARRANTY STATUS: Eligible Under The Provisions Of Bumper To Bumper Warranty Coverage
OASIS CODES: 509000, 597997, 702100
ISSUE: A "ratcheting" noise from the front axle and/or a self-engagement of the automatic hub locks may occur on some vehicles. This may be caused by a combination of high axle motoring torque and hub locks which require little torque input to engage.
NOTE: THE FRONT AXLE SHOULD BE "BROKEN-IN" FOR 402 km (250 MILES) PRIOR TO PROCEEDING WITH ADDITIONAL DIAGNOSIS OR REPAIRS. TO BREAK-IN THE FRONT AXLE, ENGAGE FOUR-WHEEL-DRIVE, DRIVE FORWARD AND THEN SHIFT OUT OF FOUR-WHEEL-DRIVE WITHOUT DISENGAGING THE HUB LOCKS. DRIVING WITH THE HUBS ENGAGED WILL BREAK-IN THE AXLE. IF THE VEHICLE IS BACKED UP DURING THIS TIME PERIOD, THE HUB LOCKS WILL DISENGAGE AND WILL HAVE TO BE ENGAGED AGAIN BY REPEATING THIS PROCEDURE.
SERVICE PROCEDURE
U2. With the left axle shaft free to rotate:
1. If all torque readings obtained in Section A, 2a and 2b, are 2.8 N-m (25 lb-in) or less, the differential side gear thrust washers DO NOT need to be replaced. Proceed to Section B, Step 2. If any of the torque readings through the differential obtained in Section A, 2a and 2b, were over 2.8 N-m (25 lb-in), replace the two (2) flat differential side gear thrust washers (Figure 2) with the 0.635mm (0.025") thick washers supplied with the Axle Motoring Torque Reduction Kit (F6TZ-4228-BA). Follow the procedure listed in the appropriate year F-Series/Bronco Powertrain/Drivetrain Service Manual, Section 05-03A for differential and carrier removal instructions.
If this procedure has not resolved the concern, call the Self-Engagement Hotline at 1-503-786-5486 (Monday-Friday, 10:00 AM-6:30 PM Eastern Time).
2. Measure the end play of the rear output shaft using a dial indicator. If the end play is over 1.27mm (0.050"), there is a possibility that one (1) of the two (2) rear output snap rings is missing or out of position. Note end play for reassembly purposes. Regardless of end play, proceed to the following Step 2a.
c. Check for a minimum of 0.25mm (0.010") clearance between sprocket and lockup hub on the rear output shaft using a shim gauge. If insufficient clearance exists, replace rear output shaft (-7061-), drive sprocket (-7177-), and hub shift collar (-7100- for manual shift and -7G362- for electric shift).
Was speed control, if equipped recall work completed by dealership? Call local dealer or register and view status @ https://owner.ford.com; or @ https://vinrcl.safercar.gov/vin/ ... have VIN ready.
See this guide by jowens1126 to confirm recall status @ https://www.fullsizebronco.com/forum/23-technical-write-ups/457065-93-94-96-cruise-control-recalls-repair.html#post6530073
Here is the 1995 Bronco Dealer Brochure
For any Bronco questions or to chat about it's planned modifications or build, it's better to post each seperately in Noobie Bronco Tech Questions. Flame free zone. This will get more attention and you can build up your post count to get into other sections such as Bronco and Ford Parts/Accessories (75 posts required to view).
Please fill out your Bronco Info with year, engine size, transmission type, transfer case type (manual or electric shift), locking hub type (automatic or manual) info & major mods such as a Lift, etc. for better responses.
Click User CP
Edit Your Details,
Scroll down to Bronco Info
Forum Common Replies to FAQs @ https://www.fullsizebronco.com/forum/21-noobie-bronco-tech-questions-flame-free-zone/165569-common-replies-faqs.html
Includes such as:
How to post pics @ How to POST PICTURES - Ford Bronco Forum
We do enjoy Bronco pics!
How to Use Search @ https://www.fullsizebronco.com/forum/19-suggestions-feedback-site-help/62157-how-use-search-advanced.html
Baba Looey's Favorite FSB Links (lots and lots of tech links) @ https://www.fullsizebronco.com/forum/21-noobie-bronco-tech-questions-flame-free-zone/131287-baba-looeys-favorite-fsb-links-lots-lots-tech-links.html
... Includes such as, How do I fix my back window?
Free registration for some wiring diagrams (86 through 96) and Technical Service Bulletins, (80 through 96) with Recalls, same as by Ford @ BBB Industries- Premium Alternators, Starters, Power Steering Products | TSB's & Wiring Diagrams
Please VOTE in our Full-Size of the Month (F.O.T.M.) & Full-Size of the Year (F.O.T.Y.) Contests @ https://www.fullsizebronco.com/forum/27-f-o-t-m-voting/
Contests will be held in JANUARY, MARCH, MAY, JULY & SEPTEMBER. Each month in-between will be used for nominating contestants to run in the following Month.
Then get ready for the Full-Size of the Year (F.O.T.Y.)⚠
Al
1 - 2 of 2 Posts
