Aren't those inverted flare fittings? With the tube going thru a male threaded nut & a flare at the end of the tube? If that's the case, the sealing is done between the flare & the domed shaped portion at the bottom of the hole. The threads don't actually seal, so no teflon tape should be needed on flare fittings. You might use something if you are installing an adapter from ips to flare, but you have to be careful to not get a piece of teflon into the open end.
As for plumber's tape, that's the metal stuff with holes in it.
