I have a 92 F-150 with a manual shift transfer case. It has the linkage to whre to shift into 4 hi you just pull back, but to shift into nuetral or 4 low you have to push down first. I do not like this feature and I was wondering if ther is a linkage I can swap over from another F-series truck or Bronco that does not have the push down feature. Is this swap possible? I was in a truck today that I believe was an 89 and it had the same shifter and same location in the floor as mine but the transfer case shifted straight back into 4 hi, the way I want mine to work. Any help is appreciated.
