kibblepup83 said:
will a set of 35x14.5x15 super swampers fit on my 15x10 rims?
Can't find specs on 14.5 but did find a spec for a 13.5 and it will fit 8.5 - 11 inch wide rims.
Here is a good place to check out tire specs for a lot of different tiers.
http://www.tirerack.com/tires/index.jsp
They didn't have yours, but you could always call the manufacturer or look them up on the net.
According to Interco's web site, your tires must be SSR's, which in the above size are made to fit 10-12 inch rim width. To verify fit see:
http://www.intercotire.com/site34.php
As Screamin_D stated, you may have difficulty at a regular tire shop in getting these mounted, too wide for many machines to work with.
Truck tire shops and 4x4 specialty shops can usually do it.
my 35x15.5x15 swamper tsl/sx's are mounted on 15 x 12s, the tire has the rim size molded into the side wall nothing less tha 12 wide. my 36x14.5x15 mickey thompsons were on 10 wides but should have been on 12 wide they had a very noticable (ballooning of the tread) not sure if thats how i want to say that but if i was to do it again they would be 12 wide wheels for any tire 13.5 or wider just my .02:beer
You change your avatar alot.
I ♥ TTB
My 39.5x15x15's, on my 15x12 rims they are balloonier than the 15x10's, should fit without a problem either way though
