So my passenger window will roll down with driver side switch, and will roll down with pass. side switch. Neither switch will roll it back up.
So I took off the door panel and unplugged the switch at the door panel and tested it with a voltage meter and it has power going up and power going down but only works the down position at the switch. So im assuming my fix to this problem is replacing the master switch.
If anyone can find this part for me anywhere on the internet and post a link I would be super grateful. If not I will go to a junk yard and try my luck there.
Thanks
PNWBronco
doubtful BOTH switches are bad. I'd bet the motor is weak. Grab some wire, make a fused harness and by pass the whole system and see if the window rolls up.
Your motor is probably weak, or you have bad wiring to the motor. window down takes far less power than window up.
Just because you have power, does not mean the wires can carry current.
:stupid
But one could be bad and making it look like both are bad.
Example: My mom had an Ford Aerostar years ago. Same exact symptoms. Replaced the driver side switch and problem was fixed.
Same exact symptoms here. I'll bypass the driver switch to test.
