1 - 2 of 2 Posts
So just had one of my most successful fixes yet.
I know I know I should be on here with a ton of questions like usual.
I was able to remove my rear window motor and replace the gears and re-install it with no major hang-ups.
I only snapped off 2 bolt heads(At least they came off).
I wanted to share the tech write-up I used for anyone who may have a motor that makes noise but window doesn't move. Here is the link:
http://www.off-road.com/trucks4x4/article/articleDetail.jsp?id=198387
Here is the link to the $14 part that fixed it:
http://broncograveyard.com/bronco/i-34554-window-motor-gear-repair-kit.html
That is instead of making your little pieces to wear down or break.
Just thought I share...
Jeremy
www.crazyaboutultras.com
OUT OF BUSINESS / M.I.A
That's a great link you provided....
Failure of server APACHE bridge:
No backend server available for connection: timed out after 2 seconds or idempotent set to OFF.
Build date/time: Nov 7 2008 15:46:52
Change Number: 1166189
1 - 2 of 2 Posts
