1 - 3 of 3 Posts
i have a 92 and the passeger window stoped working so i checked the motor and it was fine so i replaced the switch well when i roll it down some times it wont roll back up like it isnt geting power so i have to unplug the motor and plug it back up to get it to work. so i went ahead and replaced the motor and it is still doing the same thing guys im stumped. any help?
if you have to unplug and plug it to make it work, sounds like a connection problem, clean all the connectors and switch the best you can, as to make good contact, also use a multimeter and check your switch and conectors for proper power
hope it helps
1 - 3 of 3 Posts
