Couple different possibilities.
One, a hole in the hose leading up to the nozzles. Have someone press in on the squirters while observing the hose.
Two, the nozzles are clogged. Follow the hose from the box to the end of the line, remove the end of the line, then have someone press in on the squirters to see if fluid comes out. If it comes out, you'll need to take a needle and push in the holes on the nozzles.
