1 - 9 of 9 Posts
Anyone else have problems with their washer sprayers at speed? If I am going more than 50mph they don't spray very well. The wind just takes the fluid everywhere. Hardly any gets on the winshield. Any thoughts on how one could remedy this?
In The Matrix
I don't have any problems, but my sister did on her car, it would go everywhere. I just stuck a needle down the holes and tried to clean the ends out, and pointed them a little better and it works great now.
andy, yours dont work? mine stopped working randomly the other day, there is an electrical connector at the bottom of the resivoir tank, i took it off, cleaned both male and female ends of it, pinch the female end a bit so it clamped better, put it back on and it works like new...
use a volt tester and check to make sure your getting voltage at the female end of the connector when you push the botton, should be about 10v with the car off.
if you are and you have cleaned it up and the pump still wont work, hotwire the pump to your battery (make sure you try positive on both sides cause i dont remember which is which but if you get a weird noise switch them quick ;) ) if that doesnt get your motor pumpin drain your fluid and take the pump out, clean it up and see if it works then, if it doesnt, then replace it
Hey Bob, I figured I would get that for an answer. I think it has to do with my moon visor. The wind doesn't flow as smoothly up the hood and windshield as it would without it. The sprayers work fine and spray evenly just not at speed.
1 - 9 of 9 Posts
