I went and picked up 2 tubes of that stuff last nite, got a full weather strip kit from bronco grave yard. So all those little leaks and such round windows and doors are quieted down. I am not try to jack my own thread but what does ford call for for seam sealer they use on the body panels, my firewall to floor pan seal is letting water in and the a few other spots. Thank you again, no one else has been able to give a definate answer to the window sealer.
yo LC,
NP..
Seam Sealer TA-2 Fast-curing
Permanently flexible
Excellent bond strength
Paintable in 10 minutes
Will not shrink, crack or peel
Bonds to all primed or painted metals, and most automotive plastics
Heavy bodied, non-sag formula
Immediately bakeable
Typical applications include: Duplicating factory look on: standing cosmetic seams, truck bed seams, tooled door skin seams,
floor pans, core supports. Anywhere a non-sag, cosmetic seam sealer is required.
Available in 10.3 fl. oz. (305 ml) aluminum caulk tubes
SEALER SPECS:
Item; Sealer Code#; Container; Ford Spec #
Recommended BrandBody Schutz Spray Putty 1; 400g; Aerosol Pack; 3M Part No. 8883
Body Schutz Spray Putty 1 1 Liter Spray Pack 3M Part No. 6923
Black PVC Adhesive Tape (1-In. Width) 2 50m Roll ESB-M3G-10A
Black PVC AdhesiveTape (2-In. Width) 3 50m Roll ESB-M3G-10A �
Drip Check Sealer 4 150m Tube � 3M Part No. 1918
Metal Joint Sealer 5 300ml Cartridge ESB-M4G-133A 3M Part No. 5528
2695 Clear Sealer 6 500ml Can ESB-FM2G-1022A Beta 2695
3M has changed part numbers since 96 or so; so
3M™ All-Around Autobody Sealant, 08500, 1/10 gal cartridge
White, easy to apply sealant that is used for sealing interior and exterior autobody joints and seams. Applies easily and can be smoothed to a featheredge with a wet finger and sets to a firm, tough, rubber-like water resistant bead.
This sealant can be painted in 30 minutes, has easy water cleanup and will not harm paint.
Stock Number: 62553352196
UPC: 00 051135 08500 4
or
3M™ Flexiclear™ Body Seam Sealer, 08405, 1/10 gal cartridge
High solids clear joint and seam sealer designed to seal interior and exterior joints and seams. Adheres well to clean, bare metal, primed metal and painted surfaces. Clear, non-yellowing. Excellent tooling properties.
Here is the 3M Seal Sealer site
Many other Brands are available too
