yo kipp, good stuff;
here it is from 1996 F-150, F-250, F-350, F-Super Duty and Bronco Workshop Manual
If image doesn't load;
Pin Number Circuit & Circuit Function
1 589 (O) Multi-Function Switch Mode
2 65 (DG) Ignition Power (Hot in ACC or RUN)
3 57 (BK) Ground Circuit
4 941 (BK/W) Windshield Washer Pump Motor Feed
5 57 (BK) Ground Circuit
6 — Not Used
7 993 (BR/W) Multi-Function Switch (Common)
8 56 (DB/O) Wiper Motor LO Speed
9 590 (DB/W) Multi-Function Switch (Internal Mode)
10 61 (Y/R) Wiper Motor (Common)
11 65 (DG) Ignition Power (Hot in ACC or RUN)
12 — Not Used
13 28 (BK/PK) Wiper Motor Park Switch
14 58 (W) Wiper Motor HI
Refer to the following electrical schematics when performing diagnostic pinpoint tests.
Interval Wiper, Washer Circuit — Except F-53 Motorhome
Wiper Control Module Connector
http://www.thedieselstop.com/faq/9497faq/maint/stj/images/k20323c.gif
Turn Signal and Windshield Wiper Switch Connector
Pin Number Circuit Circuit Function
2 15 (R/Y) Headlamp Dimmer Switch Feed
3 13 (R/BK) Headlamp Dimmer Switch to Low Beams
4 993 (BR/W) Multi-Function Switch (Common)
5 12 (LG/BK) Headlamp Dimmer Switch to High Beams
6 590 (DB/W) Multi-Function Switch (Internal Mode)
7 196 (DB/O) Instrument Panel Lamps Feed
Wiper Motor Connector
1 57 (BK) Ground Circuit
2 28 (BK/PK) Wiper Motor Park Switch
3 65 (DG) Wiper Motor Power (Park Feed)
4 61 (Y/R) Wiper Motor Common (Run)
5 56 (DB/O) Windshield Wiper Motor LO Speed
6 58 (W) Windshield Wiper Motor HI Speed
