So far I have had a fuel system problem (fixed), ignition problem (fixed), chargeing problem (fixed) and now this new one as of a few days ago. when you get in the truck the check engin light will be on and there is bairly enough juice to light the dome light. But the barrery tests full. So when you turn the key NOTHING. Fuel pumps come on and that but No juice to turn on the lights, horn, hazards, radio, nothing. When you unhook the positive cable and touch it to the terminal you can hear the TFI mogual in the distributor click as well as a relay (believe its the ignition relay) and the check engin light comes on in the truck (this is with no keys in the truck mind you). I unpluged the ignition (under the dash) and it still does it. Olny time it wont is when you unplg the three wires comeing off the negative battery cable. My truck is a 1988 F150 4x4 with a 351 and 5 speed manual. No AC or power stuff in the cab. Just a bare work truck. If a new wireing harness dont do it Off comes the EFI and into the scrap pile those parts go. Im going 4 barrel intake with a Carb. make it easy no more computer
