1990 Bronco, 351w, E4OD, Eddie Bauer
I’m trying to remove valve cover gasket on driver side but the plastic strip for the wiring harness that slips over the long bolt to valve cover is stuck on there.
I’ve pulled really hard and tried slipping things under to get leverage and nothing is working.
does anyone have advice??
I’m tempted to just dremel the whole thing off.
1978 Bronco Ranger XLT, 400/C6 92 K documented miles &1994 Bronco,XLT 85K original miles
Typically its plastic over steel and steel always wins. Normally you can just pull/lift off. Maybe they spray/twist BBBlast O night....
did the pb blaster over night and still no change. Theres a copper ring on the harness that goes over the valve cover bolt. It's driving me nuts
Two small pry bars to lift from mostly 2 sides?
good for you.
