1 - 8 of 8 Posts
I need help with my trailer light connection on my truck. The left blinker will not work for my trailer lights. The tail lights on the truck work just fine. I have the factory connector on my truck. The parking lights and right blinker work. I am not getting any power to the terminal for the left blinker. I even checked the plug that connects to the factory harness and i have no power. It must be between that and were ever that wire goes. I have a haynes manual but i see no wiring diagram for the trailer light connection so I do not know what color the wire is that I need to trace.
If anybody has the wiring diagram it would help me out a lot. (steve;) )
Have any of you guys had this problem?
thanks in advance,
scott
Check for a blown fuse for the trailer left turn circuit in the under hood fuse panel:fuse #7-the 7th one back,of the small fuses(10 amp-red fuse).
THANKS!!!!:chili:
YOU'RE A FREAKEN GENIUS!!!!!!
Checked it and that was the problem. I did not know that they made a fuse just for the left or right signal.:doh0715:
1 - 8 of 8 Posts
