1 - 2 of 2 Posts
I just picked up an 89 Bronco and I noticed after driving it home that when I shut the truck off, the fuel pump kept running. I immediatly replaced the ignition switch, because it's cheap and wasn't sure if it had ever been done, and things were good for awhile. Then today, I drove the truck around the block and when I came home, it was doing it again. Could this be a bad fuel pump relay that may be sticking? This is the only thing I can think of.
Thanks in advance....
Call Me Ace
that makes sense.
go ahead and check fuses and relays.
then start hitting stuff with a hammer...
then actually do some investigating...
if youve got the time- drop your tank and check the pump and sending unit.
i think steve has a writeup in his sig link thingy.
ace
1 - 2 of 2 Posts
