My 87 302 won't start first time second ok then its great rest of day,new plugs ,wires,rotor ,dist.,fuel filter,cleaned the air cleaner,cleaned the throttle body any idea's to ry or look for thanks
I would check your TPS -throttle position sensor which controls TB blade angle, there are 2 styles of TPS both have spring loaded rings in the center to engage the "tanges" of the TB shaft blade at the bottom. You should make a scribe mark for positon of the TPS on the TB base for reference if you plan to replace it or take it off.
One style actually has elongated screw "slots" so you can physically move & adust it for proper voltage using a multimeter, the other TPS is where you put it in your hand turn a little CCW then set it over the TB blade end to engage the TB shaft "tanges" turn CC to line up the screw holes and tighten down then re-connect it's plug & play voltage setting is automatic.
There are other possible issues starting etc. check igniton system , timing or FPR..................
TPS wouldn't have any effect on a first time no-start. What would be the difference between the first and second time the engine is cranked?
Get a fuel pressure tester, and see what your fuel pressure is on the first time the fuel pump primes. My bet would be that the check valve failed in the FDM, and it's just taking a prime or two to get fuel pressure at the rail.
A forum community dedicated to all Ford Bronco owners and enthusiasts including the new 2021 Ford Bronco. Join the discussion about specs, photos, news, pricing, modifications, maintenance, and more!
