1 - 18 of 18 Posts
just picture whoreing. Been a while since I been around these parts.
OZ'd 400 :toothless
it was getting dark out when I finished up with this.
still have wiring and fuel system to work out. but the ETA for firing it is the end of the month.
And where has the cawk licker RAF been?
Sneaky Ba$tard
Looking great.... I've been following this over on PJB also... Can;t wait to see how it works... Fog
Wrenching for a Livin'
So thats like true multiport fuel injection....not TBI? You could prettymuch use whatever carb intake you want, as long as you get the holes for the injectors put it?
This is going to be fed by a SEFI 89 mass air mustang ECM and harness. Bigger injectors, TB and mass air meter as well as fuel pump. All wrapped up with a Tweecer RT to tune it all.
FSB warrior
Most Edelbrock intakes come with nitros bosses just not drilled, thats probably what spots he used
Yea, Im kinda at a loss on the EFI in the Nos ports..How well is that going to work? Looks like a hell of a project! Defenatly one of a kind!
Good luck Jopes!
Discussion Starter · #8 ·
actually I know of one other guy who is doing nearly the same thing as I am with his well worked 400. except he is running CHI 4v heads and thier huge intake.
Jopes I am very interested in your project, I want to do this to Potamus's Bronco.
Does the 5.0 HO and 351m/400 have the same firing order?
I do not want to put a Speed Density system on Potamus's I have located a 5.0 HO from a Mercury Cougar
Roller rockers are gay
looks good jopes, been wondering where you been. good to hear from ya.
Discussion Starter · #12 ·
been wrenching on the efi some more today. pics...
jopes, I looked up this thread after seeing your pics in bigblockbuggys' 460 EFI conversion thread. Do you have anymore pics? I'd like to get some more info on your conversion if possible. Are you using OE Ford electronics? How does it run?
Don, can you give a parts list, with the cost, for everything you've had done? I was sure I saw a list of your parts, somewhere else, but I can't find it now
Discussion Starter · #18 ·
1 - 18 of 18 Posts
