1 - 12 of 12 Posts
The one I have is pretty much destroyed. I need one for an 8.8 with 31 spline shafts. Need it to be around $50 or less if possible. If you just have the spider gears that's all I really need so let me know. I'm in Florida.
Never ending project
That's the number 1 problem with those there junk .:thumbup
No need for pics so long as it's in good shape. I'll PM you....
Ya, I know they're junk, but I got to have something cheap right now.
Ya, somehow the pinion got moved when I swapped yokes so the R&P grenaded and the traclok got worked over. Not your fault, so don't worry, I'm not upset, just have to swap gears sooner than I wanted/had planned.
The Ranger has a flang yoke whereas the Bronco had a 1350 series yoke. I think I over tighted the pinion nut and it threw everything off. I should have the new gears in within the next month. Until then I'm using front wheel drive.
Try it now!!
There ya go. I used front wheel drive for at least a couple three weeks while I had my driveshaft rebuilt then sat on my ass before I put it back in.
Sorry to hear that...the R+P in that thing was tight, unlike my last one I blew up 4 years ago which had good spider gears but a worn pinion bearing.
-Will
1 - 12 of 12 Posts
