1 - 10 of 10 Posts
While driving...If I hit a bump or hole the Bronco will jerk as if it lost gas. It recovers and all is fine until the next bump. I was thinking of a fuel filter or ? What do you all think.
5.0
88 XLT
It will just lose power for a sec. As if being pulled fromthe rear. Enough to lunge you forward. Theen all is ok. As for the bumps...I try to avoid em.
Pull codes, see if that shows anything.
you just might have a loose connection. codes probably won't reveal much, but worth checking first.
As far as which connection might be loose,:shrug
1 - 10 of 10 Posts
