I have an 1988 Bronco. Will a Y-pipe from an 83 Bronco 302 fit on my truck. I want to avoid having to buy a Y-pipe with a cat on it. We have no inspection here and I use the Bronco mainly on my own place. Thanks
should be the same
My 84 351w had the heat riser mentioned above, so my 86-and-later model bassani y-pipe wouldn't fit until I installed shorty headers that moved the exhaust manifold outlet to the post-86 location.Prior to '86 or '87 (IIRC) the y-pipe was sized to accommodate a mechanical "heat riser" flapper valve on the driver side ( IIRC) exhaust manifold. The earlier model version y-pipe may not fit on your '88.
