I'm running 33 12.5/15 on stock rims and the tires rub at full lock. Wanted to get some inexpensive replacements and was thinking about Cragar soft 8 's but backspace is 4". Most posts say 3.5-3.75" backspace is best. What I really want to know is will these rims http://www.summitracing.com/parts/CRR-3975155/ eliminate the rubbing. Thanks in advance.
Two bits that may help:
1. BDS recommended when I got my 4" lift to use 4" backspacing for 33's.
2. You can adjust the stop screw/limiting bolts on the steering knuckles to stop the rubbing, so long as you are in range.
