15 Gallon Air Compressor, found it on sale for 80 bucks at Advance Auto Parts. 1/2" 220 ft/lb impact also on clearance for 20 bucks.
This is the tool you need to buy or may already own to hold the yoke. This is what was so cool, its 2 1/4" and holds the yoke like it was designed for it.
Insert the fan wrench under the yoke bolt holes tight up against the casting.
Push the ends of the tool so it sits tight against the yoke body.
The tools are beefy and 1/4 inch thick. I used a basic 1/2 inch ratchet to hold the steel plate while i pounded it with the impact air tool. It took a long time to break the 32 year old pinion nut off the yoke of my solid axle but it worked like a charm. I would not have been able to do it without air tools.
This is what the tools look like out of the packaing. You may already have these laying around so this may be a free deal for some of you.
Tap the bottom of the yoke and it will pop right off. Replace the seal or continue on with your tear down.
