Made a trip today to grab the np203 range box off that dodge and the np205 off a 77 f150. There was also an 81 f150 i wanted to check out.
We'll start with the 81. I check under the hood and it's a 300 with not one, but TWO york compressors.
And look at that sweet front bumper and plow setup!
Then I glance up and see an underhood toolbox. Score!
But too good to be true, it had a broken latch and the body was missing a significant portion. Damn.
I noticed the actual AC bracket looked factory, so I snagged it and the York. The bracket does have a ford part code stamped in it.
The second york was mounted in the smog pump bracket, very creatively I might add. It was for an onboard air system. Rigged with an oil separator and a 5 gal air tank under the bed. I left that york. I did take the modified AC lines off it for my system. I snagged a brass fitting manifold with some sort of regulator attached. Figured it'd come in handy for my own setup. And it's like 80 bucks worth of brass fittings!
Across the aisle I spied something for my superduty, a K&N intake tube. It was just lying on the ground!
Then I went to pull the NP205 out of the 77 ford. Driveshafts were a PITA. Linkage was a PITA. Trans tunnel cover was a PITA. Got four of the 6 bolts holding it to the trans out. Then the lower two on the driver side were nowhere to found. There was 27 pounds of solidified grease-mud concrete. I couldn't get enough off to find the bolts. What a bummer. It's probably gonna get crushed soon too. Been there since 10/14. I'll take my scraper next time if it's still there.
At the other yard, I set my sights on the 77 dodge with an np203 transfer case. I decided to drop the case then take the range box off. I didnt wanna risk breaking something, so I found an old seat cushion to drop it on. Managed to drop the 200 pound NP203 to the cushion with a bit of effort. Too bad my hand was under it still! The cushion saved my hand from being completely crushed. Just a bit tender.
All of the reading I did on the 203s bashed it because of the chain drive. I have to wonder how many people have been inside one, because the chain is like 3 inches wide! That's twice as wide as a bw1356. If you've never read the theory behind the "full time" NP203 transfer case, I recommend it. It's quite an interesting unit.
The 203 range box.
Why a dodge you ask? Well, ford NP203s are nearly impossible to find these days. Dodge 203s are easier to convert to work with ford stuff than the chevy 203s.
