1 - 13 of 13 Posts
Ok, I have been searching and reading many problem related threads, no swap related threads (in detail).
I intend to start my E4oD-ZF swap this coming Tues. I have a STACK of new and Jy parts, I think I have them all.
I have a EEC out of a 95 302 F-150 which had a M50D that I intend to use, I also have the ZF wiring haress which I intend to use, these should be easy enough to figure out. I do have one issue I havent been able to answer though. If the truck would have been equiped with a manual it would have a CPP sensor, being a Auto it has a NSS. When I convert/ replace the auto tranny wiring harness with the ZF harness the NSS wiring will be eliminated??? ( I assume) The CPP harness is part of a different harness being it is under the dash??? If I don't use a CPP I realize the truck will start in gear (I don't mind).
Basicly, Will it all work if I replace the auto harness with the manual harness and don't use a CPP, or will I have to use a "JUMPER" somewhere??
Engineer
I didnt swap ecu's, I didnt swap harnesses. I jumped the NSS which for me is something I like, since I can start in any gear
Do you have reverse lights?? I would perfer to jump in and start it, reguardless what gear its in also. I have a limited amount of time once the project starts and I would like it to be as right as possible. I hate the push the clutch to the floor switch any way!!!
Engineer
Yes you need to jump those wires too
Is there anyone who has swapped ecu's and harness's willing to reply??
The wiring for the CPP is clipped under the dash with a bypass plug inserted into the connector. Pull the bypass, and it will plug into the CPP switch. It's clipped onto the dash support behind the ashtray.
I jumpered the NSS(MLPS) for back up lights and 'always neutral' on mine, still with the 5.0/MAF/E4OD ecu. I'm not thrilled with not being able to pull KOER codes, due to a solid MIL during self test (constant FMEM) and am thinking about putting in a Mustang ecu. Your 95 should be MAF, no? Is the 5.0/M5OD ecu MAF? fordfuelinjection.com doesn't list any manual trans/MAF ecu program codes. The SD/MAF is a bigger issue than jumpered wiring, IMO.
HOLY $HIT!!!
I didn't even think about the SD V's MAF. I don't know if it is a SD or MAF ECU. Is there any way to tell by looking at it??? I thought that all pickups and Bronco's were MAF after 92. I must have been out to lunch??
you should have an MAF truck. easiest way to tell is to go pop your hood and look at the TB.
I use an auto harness with a ZF... i can start in gear if i feel like it.
Discussion Starter · #9 ·
I now how to tell if my truck is a MAF, anyone who is going to swap a auto for a manual and can't do that is in for a learning exp. And yes, my truck is a MAF.
I mean the DONOR ECU, that I didn't remove from the truck myself, :banghead I ordered it from a wrecking yard on the other side of the state. They shipped it to me!!
Is there a way to DE-CODE the part number on the ECU or are the pugs different????
Discussion Starter · #11 ·
WELL,
I think I have answered my own question. The code on the Comp. tag reads:
EEC-IV EFI-SD42F
F4TF-12A650-AVA G
I'm Assuming that the "SD" in EFI-SD42F, means that it is for SD. :duh:banghead:cry
Can anybody confirm this???
1 - 13 of 13 Posts
