1 - 2 of 2 Posts
I have finally gatherd the parts to complete the swap, with one exception.
The cross member. I called a wrecker who said they had one and it was allready pulled, SWEET!! Not really, I went to pick it up and it looks alot different. My auto k member bolts to the out side of one frame rail and sits on the inside of the other. The one at the wrecker that is supposed to be for a M50d tranny is designed to sit on the inside of both rails. Does any body have a pic of the right part or a better description of the right part.
I don't have a picture, but the cross member I used for my swap came from an M5OD equipped F-150 and is stamped with "M5OD". The main piece of the cross member sits on the inside of both frame members with a bracket on both ends that bolts to the inside top of the frame members. The manual cross member will use a different set of bolt holes in the frame than the E4OD cross member.
1 - 2 of 2 Posts
