Searched to no avail....where is the vent on a ZF5? Swapping one in and was gonna run extended vent lines...
In the rubber boot?
Where could I find a replacement, mine is torn. And if I pull the top cover to tap it for a new vent, will I need to do anything else before reinstalling or is it like an M5OD cover in that regard
I got a new boot from bcbroncos.com. There might be room to add a 1/4" vent on the shift stub plate, its bin awhile since i looked at mine. Could always add one near the top of the pass side inspection plate. That should keep it well out of the fluid level. Intake it you are wanting to add an extended vent because of water crossings and such.
Yup, water crossings. I wanna play in the Platte River a bit, and while I don't plan on sinking her up to the frame rails.....no guarantees I won't.
Has headers, efan, no smog pump, and hubs have no air pockets in them. I don't plan on driving through water that deep, but in case I do I would rather not fill everything with sandy water.
