Tailgate switch in the back
1 reading
9.5K views 22 replies 7 participants last post by  bossind
#1 ·
Forgot about this mod I did a few years ago. Sometimes when we are out on outings where we camp I sleep in the back of the bronco, but it was a pain to roll up the rear window by reaching over the front seat insert a key and hitting the dash switch so I installed this in the rear panel. I can climb in over the rear tailgate, slide into my sleeping bag and hit the 2-way switch to raise or lower the rear window. Its sure comes in handy after drinking all night and need a quick exit from the bronco to go for a pee. :beer
Anyway here’s the pics for now, and if there is interest I'll do up a diagram of the wiring. Basically the relays are used to reverse the power to the motor and disconnect the dash switch when you hit the two-way switch. All the work is done right were you see, I jump in behind the rear drivers side taillight were the wires from the tailgate run and tie in there. No need to run wires to the dash or anything, its all right there. I think I used ground side switch as well so there is no power to the switch I installed. :rockon
It was nice and neat but I'm taking out my rug and trim to find a water leak so I took a couple pics while I had access to it. This fits behind the panel.
#3 ·
yeah, i do wiring for a living...and i can't think right off hand how to do that, unless you run a power wire back from the front....
#4 ·
Power already runs to the tailgate, she’s live back there. But the trick is to reversing the polarity and cutting out the front switch cause the front switch will short you out when you reverse. You want every thing to return to factory when the two-way switch is in the neutral position so the rear key and front dash switch still work.
I used to do wring for a living, now I only do special requests. Guess what this is. ;)
#5 ·
OOooooo....i like whelen....what all is goin in and whats it goin in?
Actually i install 2-way radios and public safety equipment everyday....thats right up my alley :thumbup
#9 ·
You don't need to eliminate the front switch, if you wire your extra switch into the circuit the same way the outside t/g switch is wired in. And you don't need relays, either. You just have to use a DPDT switch, like the stock ones, or 2 SPDT switches (which is actually what the key switch is).
#10 ·
Yes your right but I Couldn't find the switch in a micro format or one that would mount nicely and out of the way - not much room for a kick ass switch, plus I didn't want to run live to the switch and make for another failur location, lots of load that the relays can handle better. If my switch fails the orginal dash and key switch still works. :beer
Nice drawings.
#12 ·
Cause its big and harder to mount, I didn't like it so I did it the way I perfer. Many ways to do things when it comes to wiring, neither is wrong. Plus now that I have a ground sided system in place I can easly rig my wireless remote into rolling the rear window up and down - dam I should get on that! Also those OEM Switchs have been known to heatup and fail, there are some post on FSB about it. The relays allow the OEM equipment to work in the closed postion, if relays fail its always in the closed postion or non power postion. The relays only come into action when I hit my little switch, the rest of the time they are just sitting there doing nothing.
So yeah I did it my way and its worked for over 3 years now.
Heres a link to a problem switch http://www.fullsizebronco.com/forum/showthread.php?t=69975&highlight=dash+window+switch
#14 ·
I've seen bad dash switches, too, but for the effort & cost, I'd still use one. I'm not saying your way is wrong; just that the stock-type switch is quicker, easier, & cheaper. And if it does go bad, it's one ~$15 part to swap in a few seconds, as opposed to tracking down which relay it is & digging it out. Plus, you're still using the stock switch in the dash, so it's no LESS reliable to use another.
#15 ·
I must agree here with Steve. Yes theres alot of different ways too do this mod but, if you can use a "Factory" switch, why not? My .02
Thanx Steve for the wire diagram. I have to get you pictures of the "Low Fuel light" I keep forgetting :brownbag Plus I have to wait 'till its less then 1/4 tank {Which that hardly happens}...:rockon
Allcruisen :imp :usa
#18 ·
bossind said:
...remote control my rear window from my remote starter... Which is where I was going with this install.
Oh, REALLY??? :rolleyes:
bossind said:
...I sleep in the back of the bronco, but it was a pain to roll up the rear window by reaching over the front seat... Its sure comes in handy after drinking all night and need a quick exit from the bronco to go for a pee.
Is your nose a little longer? ;)
:histerica :lolup
#19 ·
:histerica :lolup
So now you’ve resorted to calling people liars, that’s a new low for even you Steve!
Didn’t feel it was necessary at the time I started this thread to give out all my ideas, thoughts and plans cause I may never get around to completing them and it wasn’t necessary for the topic I had started. Than along comes Steve83 with his theories and in his mind better and simpler – but yet they are only theories and are unproven. Have you ever looked at the dash switch with out the dash covering? Its Ugly and bulky! Making for a ******* of an install in the rear panel, it’s unpractical, space is at a premium so its unlikely it’ll fit in the same location, its not water proof (mine is) Don’t know about you but I run with the top off and sometimes I get caught in the rain – did I mention your switch is always hot (live wires)?
Now I’ve digressed and become another Steve with too much opinion
:twak
#20 ·
The laughing smilies were SUPPOSED to indicate that I was just messing with you. :shrug
Yes, I've seen 1 or 2 dash switches, and yes, I know how much space there is in the bedwalls. Rain wouldn't affect the stock switch in the location you mounted yours for a few years. Even longer if you took a FEW steps, but I get the impression you don't care. :brownbag
BTW
I'd categorize my "theories" on wiring as well-proven.
