I'm attempting to add a 3rd window switch to the bronco, inside the cargo area for when I sleep in the back of my rig. Basically I bought a (On)/Off/(On) 12V 20A switch. I ran 3 10ga wires through the cargo area into the taillight area.
Basically, here is my setup, sorry for the lame paint schematic action.
The problem is, when I use the new switch, the motor is SLOW, extremely slow. The window goes about a 1/4 of the way up then stops. I have tried just jumping the up wire to the power feed wire, and it's still slow, however the tailgate key still works great.
If it's not the switch, and not the wire size, I can only assume it's because of these stupid splice connectors:
Do you guys have any insight? Should I just cut each wire, wind them together, solder and heat shrink?
Any ideas why this could be happening aside from those splice joints being sub-par?
Thanks!
-Alex
