Did this repair to the motor of my '83 a few years back and never got around to posting it.
Now that I have the '85 to work on I am going to rebuild all the motors the same way and figured I'd post it since I dug the pictures up.
This works for all the window motors, sides and rear.
11mm Steel Ball Bearing I found at the local Ace store for just a few cents each.
Items needed.
Philips screwdriver
Grease - I use Red High pressure molly.
3x 11mm ball bearings. (or the pack of three plastic plugs from the automotive store)
1x Motor.
Pretty simple to do, the hardest part is getting them out of the doors, but i'll leave that to other posts.
Motor needing repair.
Remove the screw.
After popping off the cover you have the gear exposed.
Look at all the little bits, my plastic plugs had exploded.
Uploading more Pics.
Items needed.
Philips screwdriver
1x Motor.
Remove the screw.
