I have to replace the oil pan gasket on my 89 5.8L. I am going to remove the fan shroud and upper plenum to jack up the engine.
I have 2 questions with this technique that I have not been able to find.
1. How high up (inches) do I need to jack up engine to get enough clearance to pull out the pan?
2. Can you get the engine high enough as not to remove the oil pump?
I feel like not having to wrestle getting the pump back on when sliding the pan in would make my life a lot easier.
