Hey guys, pretty sure i know what happened but lets see what you guys think.
Im driving home from work in my '90 351W bronco with a e4od and 4.56's 33" tires. As im driving in over drive at maybe 60mph 2400rpm, it starts slowing down and RPM seems disconnected like in neutral, when i rev it a little i get nothing and hear almost what sounds to be a rattle that is consistent with engine RPM.
I pull over and stop with the truck still in OD and tap the gas to see if first is working. it jerked forward so i knew i still have power to the ground. i start driving and a couple of seconds after shifting into overdrive same thing, like i pushed the imaginary clutch in with the rattle consistent with engine rpm. once again pulled over.
I was quite far from home so i figured id keep trying, i put it down into "1" and started again, then shifting manually into "2" and then into "D". third gear seemed fine but as soon as it shifted into overdrive same outcome. I pulled over once again and turned overdrive off seeing as every other gear worked ok.
I proceeded the rest of the 30 miles home without another issue.
Im pretty sure my overdrive is shot, either the band is worn out or the seal in the servo is gone. Is there any possibility it would be something else? something that wouldn't require a full transmission overhaul?
CLIF NOTES: truck drove fine, overdrive went out, pulled over tried again same outcome, drive 30 miles home with the overdrive turned off without a problem.
Pretty sure its the overdrive band or servo, any other possibility that would exclude entire transmission overhaul?
-Dan:cry
-Dan:cry
