Fuel Pressure Regulator Gasket
100 views 7 replies 3 participants last post by  NYFSB
#1 ·
My truck has been in a shop for over a year due to it not running right after a rebuilt. I picked it up a few days ago and I have come to the conclusion that it's truly running Lean. First concern (of many) was that the Truck was not maintaining Fuel Pressure with key on, engine off (any thoughts)?? I went with Aeromotive Adjustable FPR (saw that jermil01 was running it). Lost the gasket upon installing. See pic below, all replacement FPR's have a one piece gasket. Will that work? I can't find the individual flat gasket like below. Larger hole in FPR mating plate doesn't have recess, I don't understand why all FPR's are suppling the one piece gasket that goes around both tubes (even Motorcraft replacement).
#4 ·
Thanks for the heads up! Do you recall what type of gasket you used?
BKO is running extremely Lean, if I got on it, even in slow speeds it would buckle and struggle. With new FPR, around town is normal, only struggles with highway driving now. I have it set at 60psi, but still loses all pressure when engine is not running (Ignition On).
#6 ·
Agree with @Gregor , 60 seems real high. I have a tune in my Bronco and the pressure is still only set at 50.
I'm surprised you were able to get fuel resistant o-rings at a hardware store.
FWIW, the aeromotive FPR on my rig has been relatively trouble free.
#8 ·
I need to start a new thread after I get to the bottom of this FPR issue but this is not a stock engine, in all honestly I don't know what the correct Fuel Pressure is, but stock is to low. I cannot get anyone to tune this engine in my area.
Back to FPR, below video (16:10 mark)shows what I was referring to in regards to gasket. Every FPR I found has the one piece gasket that goes around both tubes, tried to use but it is leaking (obviously) and O-ring was leaking as well. I am going to hit a Speed Shop near me tomorrow and see if the have these flattened O-rings.
