Headlight switch?
9.1K views 6 replies 4 participants last post by  packagerjr
Where can I find the parts at? The turn signal switch was done by the previous owner. and it's just the high beams that flash, it's not like the truck is turning the headlights, running lights, etc on as well.
I see you have a '96, so the relay upgrade may not be applicable. My 80 has a separate headlight switch; sounds like yours is all integrated into the MFS. Anyway, if you do get to digging and the upgrade is applicable, here's one thread:
https://www.fullsizebronco.com/foru...-technical-write-ups/204939-another-headlight-wiring-upgrade-relay-install.html
It's just a harness that plugs into one headlight connector and supplies direct battery voltage via some relays that are actuated by the headlight switch. It eliminates full headlight amperage running through the switch, which is a known fire hazard on models wired like that.
