Anyone have any pics of a 92-96 Bronco with 15x12 rims. I dont care about tire size I just want to get an idea of how much more they stick out (Based on the proper backspacing which is arund 3.75" I think ). In the pics sections I didnt see any.
and when was the last time you aired down below 10psi?southrncomfort said:i have 15x12 on my bronco with 35x12.50's havent had any prodlems with them
never had to air down below 10psi, and dont plan on having to do so, not many sandy places around here :toothlessAndy351 said:and when was the last time you aired down below 10psi?
Stoked said:12 is crazy for only a 12.5 tire. if you are only going to be running a 12.5 wide tire, you only really want a 8" wide rim, 10" rim does alright, but once you air it down, you will be leaking and blowing beeds more often than if you had a 8.
heh yeah your right,reptillikus said:oh, and i dont recall SizeMatters ever saying that he was going to be using them on 12.5" wide tires....
dont shoot the messanger. lol. im not shure what to think. i herd this outcome from the mailing list from a local 4wheeling club. what was said is the 10" rim with the 12.5 tire doesnt air down to 10psi well, it will leak on you and is more likly to loose the bead. just what ive herd.93F150 said:with all due respect, you must be outside yo freakin mind! I run 33x12.30s on 15x8s and the truck will damn near change lanes without touchin the wheel. I run them at the suggested pressure and sidewall movement is scary when the wind starts blowing, or when you go to change lanes, basically anywhere you are required to turn the steering wheel :wacko
As a general rule i would keep your rims not more than 2" narrower than your tires. I have a set of 15x12's that I'm mounting my 33" dunlops on (13.25 actual section width) hich should handle decent on the street and still be able to air down (which is why I bought 12.50's, so I wouldn't have to air down) Maybe you guys with the BFG's have a section width that is smaller than advertised, like 11.50 or 12.00... my dunlops are almost an inch wider than advertised :shrug
(ps, I used to sell tires for a living, don't preach to me about how to measure the section width of a tire)
in the sand, my 35s are frequently below 10psiStoked said:what was said is the 10" rim with the 12.5 tire doesnt air down to 10psi well, it will leak on you and is more likly to loose the bead. just what ive herd.
